P
paul-haggis
Guest
Hi Craig,
The Timecert cutter has a shoulder on it to govern the depth of the insert counterbore. Dont' manually hold this back so the insert is dead-flush - all metal is elastic and a dead-flush insert will be slightly proud of the surface once the stud is tightened and everything gives a bit.
The stud goes right through the insert by the way and will bottom out in the hole in the head.
HTH, Hag.
HTH, Hag.
