Stoutgoose
- UK
When I bought the bike tick over was awful and uneven below 3000rpm. Upon dismantling the carbs I found that one of the pilot/secondary jets was completely blocked. I managed to clear this with fine wire and compressed air, and took the opportunity to remove the remainder of the jets and blow them and the drillings through. Upon reassembly the bike ran much better at tick over and could be ridden at below 3000rpm. I have dynamically balanced the carbs at 2000rpm using a manometer, but the carbs are still stumbly and intermittent between 2000 and 2800rpm especially when trickling along in slow traffic at small throttle openings.
Cams and engine are standard as are exhausts. Jetting is standard with idle circuit set at just over 1.5 turns which provides best running. Witt electronic ignition set at 32 degrees on number 2 curve.
I am going to pull them apart again and repeat the process, but before I do, how do your bikes ride at revs between 2000 and 3000rpm on light throttle openings? Is this just how they are or should it be completely smooth?
