Arnstein
- Kristiansund, Norway
Is Kristiansund in Portugal?Probably when road works, still do without warning in the middle of a bend sometimes.
They’re easy enough to take off…I had gaiters for years but once I started investigating how my forks performed it's very hard to see whats happening with them. It's a shame they're not so easy to put on and off without quite a lot of work.
It might be worth trying what I've done, on mine, since the '70s.I like them, I had them on for more than 25 years. But you cannot do the cable tie travel measurement trick with them fitted so they had to go. Maybe I will fit them later as they do help keep the seals free from damaging grit.
Haven’t you found the sweet spot yet Vince? I presumed you were all over it.I spent a few months adjusting fork stuff, well I am still doing it.
Aha! Now we're getting to the real issue. What you need is an adjuster screw in your head to dial your imagination up or down.Might just be my imagination.
Aha! Now we're getting to the real issue. What you need is an adjuster screw in your head to dial your imagination up or down.![]()
That's actually how it should work; faster = better response. The emulator valves respond to fluid pressure. Hitting a bump fast produces rapid movement of the fork leg and a sharp increase in fluid pressure. The emulator valves responds by quickly bleeding off pressure, which allows the forks to give and the wheel to move with the road obstruction instead of simply bouncing over it. The fixed orifice holes work ok to a point, but being fixed they don't allow a measured response to sharp increases in pressure/flow, which is where the emulator comes in. At low speed/low pressure input they typically - depending on settings - don't do as much because there isn't as much fluid pressure working against them. You can spend days playing with different emulator springs and settings ...Naa, just one more 1/2 a turn soft on the emulator preload, bit like just one more wafer in that Mony Python movie and the fat bloke explodes. The odd thing is some days it's great and some days it's as harsh as always. Might just be my imagination. What is interesting is the faster I go the better the suspension seems to work, trundle along and it's way more jarring.
Sorry, Mr Policeman I have to go hard or the suspension doesn't work.
