Were the seals leaking?Really 300 ml SAE 10, just 150 came out![]()
Through the drain plug or out of the top with the fork off the bike?Yes, but they did not lost 150 ml. I will change them tomorrow.
Yes, though some add more.Hi,
the question is, is it corret that each fork leg of the RGS fork has to be filled with 300 ml SAE 10 oil?
Andre
YesHi,
Disassembled the fork and just about 150 ml came out.
Andre
Yes - has no effect on damping (which is controlled by viscosity - and internals).Doesn’t filling the forks to a higher level give an air spring effect under heavy breaking?
Kinda echos my experience too, Dave.I'm probably opening up a 'can of worms here but <snip>
