RGS front sprocket
  • Thread starter Thread starter Reggie3cl
  • Start date Start date
R
Reggie3cl
Guest
One day this will sink into what passes for my memory but does the front sprocket go flat side in or out?  Mine is out at the moment and I'm not sure this is right.
And I did do a search, honest  :D
Hi Reggie,
Flat side out is the norm - it also gives you the opportunity later on to fit 'flat side in' when the splines wear on the shaft and you can then still get a good fit on the previously 'unused' areas of splines  ;)
HTH,
Alan :)
Ta.  Unfortunately some of the wear is on the splines of the shaft :o  I'm going to see how the new sprocket fits- on the 180 I used to have to put a good amount of heat in to it before fitting- may have to use  a bit of 660 to stop further wear.  Not going to get too worried though- I won't be doing that many miles on this bike for now at least.
