impamentor
- New Forest, Hampshire
Hi Guys
Been doing some work on the RGS of late (new clutch installed, all good) along with other bits and bobs ..cut to the chase, one of the tank taps started leaking, (those shite plastic things) so decided to whip it out and take a look, on doing so found quite a bit of rusty crud on the filter. On further closer inspection looking down the filler tube, oh dear lots of rust down there.
So the questions are, what is the preferred tap replacement and what is the best way of cleaning the rust from the internals of the tank..
Many thanks in advance and sorry if this has been covered before (I couldnt find it thru search)
Graham
Graham
