ksoholm
- Bellingham, WA, USA
I'm 50/50 for either. The head's off to be rebuilt - soft seats and all that - what do you lot think?
Thanks -
Kristian
Thanks -
Kristian
Did you upgrade the cams when the carbs were replaced w/ Mikunis?
Hi Kristian
My suggestion:get your original cylinder head refurbished and spend the money on a set of new carburetors: Mikuni and buy a good ignition system and always run the best sports tires.
Br
Peder
Hi Kristian,
First of all: what is your desire and what your budget? If it's a bit more power (roughly 10HP/Nm can be achieved if everything is right; with the right exhaust even more...), but it comes at a cost (as allways).
The 41mm Inlet do help the bike to breath a lot better. Reason being is that the bigger seats do move the edge of the top of the seat ring into the aloy of the inlet port, wich reduces resitance. Also, the bigger opening does help to breath a lot better. This is compromised by - if existing - the original exhaust design. F.e.: my 1000 SFC put out 97HP with the original Exhaust (which is roughly 10-12HP more than an RGS with the same cams and I think also the same compression), had a HUGHE dent in the power-curve in midrange though but ran nicely. When I changed the exhaust to a one-off-designed one from SR-Racing in Germany, the dent was removed, torque was massively improved (from 65 to 80 in midrange) and the top end gained another 7 HP!
So - once you are "on the hunt" for improvements, you are soon running into restrictions and will need to spend more money to free up existing power.
Also keep in mind that you are filling the cylinders better, which might cause more stress to the crank/big end bearings. Depending on how old your engine is in terms of millage and wear, you might want to consider work there, too, at least in the future...
Lothar,Hi Kristian,
Agreed, great grind for stock RGS but considering all the mods done to your bike Megacycle offers a 120° F-1 grind w/ a little more lift than stock-. Cam # 584-X9No, I think the F1 cam is prolly the best overall cam Laverda ever made.
Well, I hate that question as everyone understands something different when you say "rear wheel HP"...Lothar,
Is this rear wheel horsepower of crank shaft? Also, is the SFC 1000 motor as factory or are cams and carbs different?
Impressive numbers for an antique two valve motor.
