henrywillms
- Canada
I have problem with my RGS I am trying to diagnose, with no luck so far. Looking for some ideas in hope of identifying the problem in the next couple of weeks before winter sets in and I can't do any test riding.
Motorcycle:
RGS with Witt 2 ignition/ optical sensor
Modern coils...from Wolfgang...forget the brand, probably 10 or 15 years old
Other changes to stock wiring:
Alternator phase that ran to headlight switch now plugged directly to Regulator/Rectifier
headlight relays running from fuse box to headlights, trigger to relays via factory wiring/switch
Volt meter wired via a relay to battery and switched from taillight power wire (headlight switch can turn it on off)
Problem:
WITH HEADLIGHT ON: When accelerating hard, such as coming out of a corner in a low gear at low RPMs and reving up to from low rpm thru and up to higher RPMs the ignition appears to be intermittently cutting out several times thru this acceleration. Bike still reaches high RPM but you can hear it cutting out and in. It feels much like when a spark plug cap contact to sparkplug plug terminal is worn and vibration causes a misfire. This misfire occurs every time it's under hard acceleration but intermittently throughout the acceleration period. It stops as soon as you stop accelerating and reach a constant RPM...typically in the 3500 to 5000 RPM range for me.
It does not happen at constant speeds or when accelerating slowly or only increasing RPMs by couple of thousand RPMs.
WITH HEADLIGHT OFF: Bike runs perfect. No misfire/cutting in and out under any conditions. As soon as you turn the headlight off the problem goes away, even when you turn it off during the time I am accelerating hard and its misfiring. If I turn headlight back on the problem starts immediately.
The bike had been running fine and I made no changes to the bike. I thought there maybe problem a month or two ago in my normal riding in the flatland straight roads where I live. But I really only ride it hard when I am passing someone on the hiway, ie going from 90kph to 130kph. In this scenario it is mildly noticable. When I spent a few days riding the twisty, hilly Wisconson back roads the problem was there accelerating out of every corner.....but it sure was fun so I just rode with headlight off.
Diagnosis and changes so far:
I thought it may be a lack of voltage/amps to the ignition based on headlight off, there I'd no problem
Replaced the battery. Old battery (Odyssey PC680) tested ok ( volts 12.2 and load test showed maybe a bit weak ) and it was 11 years old.
New Odyssey is PC680 equivalent
My voltage at highway speeds (4000 rpm range) is 14.2 to 14.5 with headlight off, and 13.5 with headlight on. Voltage can get a bit lower in city driving, say 13.2 but I almost never ride in the city
Alternator phase test, alternator wires unplugged from regulator, measure A/C .....voltage rides to 80 at about 5000 RPM or so
Wiring and connections
Visually checked most of the connections on the bike for corrosion and contact. Battery, grounds, alternator to regulator, Witt multi pin and at coils, to optical sensor, ground and power.. Multi pin connectors and bullet connections under gas tank, close to coils. Fuse box terminals and wires. All were clean and tight
Didnt check ignition switch, other switches or at guages. Didnt use multimeter to check for voltage drops except at headlight and it was good. Didnt test coils...just realized I probably should have.
Spark plugs and caps have maybe 2000 km of use. Replaced late last summer. NGK 5000 ohm resistor caps are tight fit and and have correct resistence. Plugs are non resistor Champion N3C. Visually look like they are running good, though I know a visual check is not that accurate with modern fuels etc,
Have not tried new plugs or caps given they are almost new.
Checked the Witt optical sensor visually to make sure it was clean ....it appears clean but blew compressed air at it anyway.
Now what?
None of the above found or the fixed the problem.
It seems to me it's either a faulty connection, either vibration or resistance related, that the increased 12v DC power with the headlight turned off can overcome. Or a lack of enough DC power for the ignition system, or a faulty Witt box; again when the headlight is off the problem is overcome by increased DC power.
A loaner Witt box would eliminate a lot of searching if that's that is the problem. Are they prone to this sort of problem?
It sounds unlikely it's a charging problem unless the regulator can fail one one incoming phase so it is not producing enough of a charge? Any way to test that? Or just replace it....its original.
I will test the coils but I dont expect to find anything...with my limited understanding anyway
I can try news caps and plugs....just in case.
Look for a poor wiring connection...like a needle in the haystack.
Gentlemen????
Motorcycle:
Problem:
Now what?
Gentlemen????
