tom3c75
- Cape Town South Africa
Been doing a few maintenance tasks on my RGS. The main aim was to resolve some clutch slip that occurred under load. The primary chain and clutch were relatively quiet, but since the bike has done about 30K kms, I decided to also change the primary chains while I was at it. The clutch plates, rubbers and chains were all original. I did the following:
1. Checked clutch plates for wear. They were within spec at about 2.95mm.
2. Removed the small springs on plates 7 and 8.
3. Added a steel plate between the 7th and 8th plates.
4. Oriented all the steel plates with the rounded edges facing inwards, i.e. towards the gearbox.
(The rounded edges had been facing outwards).
5. Checked and retained the clutch rubbers, as they were not particularly hardened or cracked.
6. Replaced the two single primary chains with a new triplex (supplied by Wolfgang).
7. Engine and primary sprockets are triplex. I could not discern or measure any difference between the outer, inner and centre sprocket rows.
8. The existing chain tensioner was retained.
Now the clutch no longer slips. However, when idling in neutral the primary/clutch seems a little noisier than original. Not excessive, but noticible to my obsessive ear. Yet, the noise completely disappears when the clutch lever is pulled in, it's almost as if there is no chain or clutch in place! Out on the road everything operates as normal.
I realise that the wear grooves in the tensioner no longer correspond with the triplex chain. But my reasoning was that the triplex chain would soon wear new grooves, and the plan is to check the tension after a few hundred kms. Also, other than checking for hardening and cracks, I did not check for slack in the clutch rubbers.
I'd also like to refit the two small clutch plate tensioning springs, but will first need to size down the added steel plate. Must admit that I'm at a loss as to how to fit those small springs without a special tool.
Any ideas about the primary noise in neutral, with the clutch out, will be appreciated.
Thanks, Tom.
Thanks, Tom.
