Fascinating - thanks for reporting back. Fingers crossed that it stays fixed ...Found the issue. <snip>
Yea when you get a chance to get at least 1 good pressure maintaining cycle such that the pedal feels rock solid just once and you "set" the lip seal often systems then work from then on. I always prefill parts as i assemble them using a 25mm diameter syringe so im making fluid come out a joint as i tighten it up (just chuck water over the mess to neutralise and wipe up as brake fluid is hyrascopic but also damages paint) using thius approach Ive always managed to bleed a brake with ease but this one I could get the pedal solid and then it would just loose than again if not in 10 cycles then overnight, drove me nuts!A very common topic on here, rear brake bleeding. I have a Brembo rear m/cyl from a Yamaha R6 and I had no end of trouble getting it to pump. It exhibited all the symptoms you describe, indicating that the lips of the seals weren't making sufficient contact with the cylinder wall. In the end I think I succeeded by filling every possible cavity with fluid, basically flooding the thing. I do recall I was on the verge of tossing the m/cyl when I FINALLY got some fluid to exit the bleed nipple at the caliper ... from that point it behaved normally and has worked perfectly ever since.
Yes brake calipers function by deformation of the seal around the slave cylinder/s normally square in cross section the shape of the groove in the caliper body where the seal sits is designed to allow the atmospheric side on the seal to "flex" out slightly with the caliper movement. At this point the deformation force as the seal "tries to get out the gap means the hydraulic force is effectively pressing the seal to the piston walls with such force it grips the piston over the last 0.1mm movement and deforms to a romboid cross section, this deformation results in a massive elastic forces within the seal.I remember years ago a mate who was a Mechanic showed me how square-shaped brake seals had a direction to fit. I forget the details, but it had something to do with their lip shape working better if installed to suit that shape in their direction of travel. To show how long ago that was, it was around the time they started swapping steel, rusty brake pistons for alloy ones; everybody was mucking with seized brakes around then, and rebuilds were happening a lot.
This bit is pure guesswork, but maybe my mate was referring to a preformed shape in the seal caused by its manufacturing process. A bit like the sharp edge formed in steel washers or clutch plates on one side as they get stamped out. He reconded he could just see a preferred side. Maybe it was just his ideaMy assorted box of caliper seals all have edges that look the same to me and those in packets dont contain any instructions or markings
Thanks for that. Going back to my experience, I ended up being directed to this forum as thats literally what i described in a google question "why do I not get any pressure to at least start bleeding my motorcycle rear brake?"The explanation is great and works once the lever will produce pressure. Many on here have not got the master cylinder to produce any pressure to tie back or hang a weight from.
I think it all cases loading up the brakes overnight deforms all seals to adopt the perfect "set" so improves things all round, moto x boys swear by this trick.I've never looked into it but thought perhaps the groove in the slave cyl was slightly tapered, giving a leading edge to the seal the same way a directional seal would. True that even if seals look excellent, they can fail to function properly. The Sumitomo blue-spot R1 calipers I use were binding slightly on release - i rebuilt with new seals - the old ones looked and felt perfect - the new ones resolves the problem.
I also wondered if tying the lever to the bars could aid seal expansion if there's no pressure to start with; the seal will just be sitting further into the m/cyl bore but be no different in shape from the fully released position.
Totally agree the tie back method makes no sense if the voodo explanation is "it gets the air out"as there is no where for it to go its by definition a closed system but after weeks of trying it instantly worked and stayed working, I belive it deforms the master cylinder lip seal to an optimal "set". either way it works.As long as any air within the system is trapped and cannot escape, no amount of pumping at the lever will budge it. The amount of fluid moved by a single stroke of the lever is usually far too small to effectively move a large air bubble along the brake line. This method may work OK on cars with a much larger M/C moving maybe 2-3 times as much fluid per stroke, but the tiny amount of fluid shifted by the common for us Brembo PS14/15 M/C is pushed straight back into the reservoir by the pressure of the compressed air bubble or even just the to-and-fro movement of said bubble.
Fill the system with fluid and place the bike so that there are no traps for air bubbles along the path of the brake lines (loops, splitters, switch housings, etc), ie, make sure any trapped air can rise all by itself. If necessary, lean the bike against a wall, keeping an eye on the angle between M/C and brake line exit. In many cases, I've simply removed the entire braking system en bloc and rigged it up on the workbench. Once air can find its way to the M/C junction, it's mostly just a matter of moving the M/C piston seal just past the bleed hole of the reservoir and bubbles will escape into the reservoir. A wooden wedge inserted between the caliper pistons prevents them from popping out. In 98% of all cases, I have been able to attain a decent pressure point within minutes, even with the system still installed on the bike. In the rare cases this has not worked, success came around after the M/C recieved new seals. Another common fault is an incorrectly installed M/C piston that either does not cover or free the bleed hole to allow fluid to be pushed into the brake line. Many RGS/SFC1000 rear M/Cs fail as soon as their piston is moved beyond their normal working range, a rebuild with new seals is seldom successful. Unfortunately, replacement of the M/C is then the only remaining option. The pumping bleed method should be avoided on these. If the M/C worked up to that point, the first stroke that pushes the piston further than usual may destroy the M/C! I don't have a viable explanation for this phenomenon, just that I've experienced it many times. Thankfully, the box of rear M/Cs was well-filled back then.
I generally use a vacuum tool to fill/renew brake fluid, rarely takes longer than 10 minutes to get a rebuilt system working as it should. Same tool can be used to quickly replace fork oil, drawing oil from the drain screw into the slider, provided the top stanchion seal has provision of some sort for attaching a vaccum hose.
New caliper seals can restore "feel" at the lever in many cases, the wooden feel of many Brembo systems result from the tiny amount the pistons retract once brake pressure is relieved with old seals. New, pliable seals will retract the pistons much further, resulting in a little more travel at the lever with a far more pleasant action.
I've never bought the "tie back the lever" trick. All it does is pressurise the system and if the M/C seals work as they should, nothing at all will pass them, in neither direction.
