murphus
- Lost in the Midwest
Taking the sprag clutch apart on my '83 RGS. I've never serviced it and while I haven't had any issues I figured best to get in there before things go wrong. My RGS has about 75,000 miles on it, a bit over 30k put on by me. Not surprisingly, someone's been in there before, evidenced by the red loctite that had been applied to the 10mm bolt securing the flywheel/sprag clutch to the crank. Said bolt came out with a rattle gun, but the flywheel won't let go of the crank. I'm using a 10.9 16mm bolt to remove the flywheel. Initially used a 24mm box-end wrench striking it with a heavy hammer to try and remove the flywheel. No go. Then applied the rattle gun. No go. Should it be this hard to get the flywheel to let go? Suggestions for locking the crank to get better effect? Assuming I get it apart, will be interesting to see what I find as there's metal swarf evident in the flywheel, stuck to the inside edge. Also, there was no thrust washer on the outside of the idler gear. Should there always be one?
