I am having trouble starting my RGS from cold. Compression is good, valve clearances checked and carbs rebuilt. This has helped a little but not resolved. A spray of easy start gets it going and then it will start and running and idle. It still spits and pops when starting 'warm'. Plugs were clean and after a few starts and short static running I removed them and the right hand one was a bit black the other two virtually clean just very little light brown. It spins on the starter quickly and the battery voltage does not drop below 11.5 volts.
Could this be a weak coil on the right hand cylinder? If yes what is the best way to check?
What else could I be checking.
Thanks
Thanks
