Reunited Chris
- Sydney
I recently lined my RGS tank with a Caswell tank lining, but after the lining had hardened off and the fuel gauge plug removed I noticed a small area on the tunnel of the tank had not been covered by the Caswell.
To cut a long story short I don't think there is enough material in the motorcycle kit to cover the RGS tank, its surface area is too big. Either the car kit or 2 bike kits would be sufficient.
Caswell advise not to re apply lining material after the original has set, it won't stick to itself.
The question is;
Is there another liner that would adhere to the Caswell liner?
I realise that I can use as is untill the lining breaks away from the tank wall.
Any advice appreciated.
The question is;
