Brett,
All o-rings are new, as are the inlet manifold rubbers.
All jets are new.
Floats are good and level is correct.
Exhaust is new, standard, no leaks.
Air filter is standard, and I still have the snorkel on it.
Checking the DMC earth is a good idea.
I synch at idle, but check it stays good as you open the throttle.
If all else fails, I will rebuild my spare set of carbs, and swop them out
Anyhow, I need to finish off fettling the 1000 SFC, because I want to ride it to the Heftrich rally, then I will have another go at the RGS.
Thanks for the suggestions
Steve
