Ringo
- Norfolk England
Can anyone give a step by step procedure of how to remove the fairing please
Many thanksIt really is that easy, only the painted part needs to come off, the fairing support frame, the black bits and the screen stay in place, so as mentioned above its not hard, when refitting take care over the mirror bolts and make sure they pass through the support frame holes etc, you will see once its apart. If you need to take the rest off, unlikely, it comes away in one piece, undo the bolts through the tank on each site and look where the fairing frame meets the headstock, around there is a pinch bolt (singular) undo it and it should slide off (obviously wires and hoses as well) honestly though, the frame and black bits are a pain and best left installed
Roberts ya mother’s brother.
Fitting the fairing at the mirrows could be a bit difficult, screws should be chamferdMight be easy to get it off, not always so easy to get it back on again!![]()
He didn't ask how to install it-Might be easy to get it off, not always so easy to get it back on again!![]()
Depends on what battery is fitted now, but it usually comes out through the LH triangular gap between the frame tubes. You may need to temporarily remove the rear brake reservoir.Interesting another question how do you get the battery out and any recomendations on replacement battery
12 yrs Al ……. Now that is value for moneyDepends on what battery is fitted now, but it usually comes out through the LH triangular gap between the frame tubes. You may need to temporarily remove the rear brake reservoir.
Odyssey PC680 is my recommendation - previous one lasted 12 years.
Alan![]()
