beauchemin
- Victoria, British Columbia
The Ross Racing Pistons installation sheet is here: http://rosspistons.com/information/racing_rings_installation.pdf
The gapping instructions are a bit vague. It says in most cases the gap = bore size in inches X .004 --- That equates to 0.30mm. (The factory manual gives a range of 0.20 - 0.30mm.)
I have questions:
1. What should I be using with these pistons, in fresh bores?
2. Should I be setting the second ring to a larger gap, as Ross recommends?
Thank you!
Chris
I have questions:
Thank you!
Chris
