I need to take off the alternator from my 1200 triple so that I can fix an oil leak from that side. It seems that the casting has distorted at the lower edge so will need to be removed from the engine and machined flat. Or I might get away with flatting it off with some abrasive paper on a sheet of plate glass.
Am I right in thinking that the thread on the rotor is M45 x 1.5? If so, it looks as if I can get a British made puller from GB Motorcycle Products for about £30. Also, do I need a rotor holding tool to do this job? I'm thinking that the rotor nut can be undone simply by putting the bike in gear and pressing on the rear brake, in which case a holding tool is not needed.
Anything else I should be aware of before I start on this task?
Any advice welcomed!
