FWIW, Just had a novel issue with persistent stationary Jota ( yes i know, not meant to be stationary ) and LHS RS36 leaking over flow tube from the float bowl ( i do connect those outlets and route away from the back tyre ). Imagined it was a sticking needle seat, not so, was the oring with compression set, leaking past the seat body, plus never knew there was a clever gauze filter a'top of the seat, which had some solid matters from the tank trapped.
Have a kit of Orings here, sorted in minutes. Is the correct float height at 18m/m correct, indulge my lack or search the forums...read it somewhere. Tah j.
