Grant said:I would think this was a minimum requirement with USD forks.
But that is only a start, Grant.
The original triple frames crack just above the horizontal support tube to the spine. Your system makes the imediate headstock area nice and stiff, but increased stress will now occur just below the support tube. Probably won't do much harm as there is a long stretch of tubing to the front engine mount that can flex as much as it likes without cracking up. The spine will also flex, but won't fracture due to its sheer size. So that's the fracturing out of the way, and will most probably be all you need with stock bendy forks. Fitting strong rigid USDs might/will accentuate the flexing and open another can of worms...
Attached pic is of my shared track bike under construction. The headstock bracing is way over the top, I wasn't present when it was done, unfortunately. All finished and powder-coated when I first got to see it!
MotoGP constructers actually seek to include a certain amount of flexibility to enhance traction and ridability.
Is that sixpence now?
