The fork ones allow you to bleed out any pressure that might build-up, that's about all and that's a good thing
Not sure about the SFC1000 but the forks on an RGS have very rudimentary valves in the fork caps; they supposedly relieve pressure within the forks under compression I guess to reduce the risk of blown fork seals. I drilled my fork caps out and araldited a set of Shraeder valves in. Have been able to run only one fork seal in each leg without blowing them.
Pure nitrogen is just that, no moisture.I thought the use of nitrogen was to avoid water vapour in compressed air, but I am no Ohlins tech. I think you can get water vapour catch tanks on air compressors used in Spray Panting, just had a thought can most compressors get to 140psi?
That's right Chisk,Unless they are Fournales, that's another story: https://www.sip-scootershop.com/en/product/shock-absorber-fournales-rear_FS1002C
Isn't that right Ausbean?
Same spring and ball on SF1 Cerianis.The Marzochi's on my 1200TS have little balls and biro type springs in the centre of the fork top nuts under a drilled screw, this relieves air pressure on cmpression,when it is great enoiugh to overcome the biro spring, i.e not a lot, works for me. I recently saw one with the ball and spring one side and nothing at all the other side (under the screw) the rider didnt seem to notice.
Same here. I messed about for ages trying to get the pressure right in my Stradas. They leaked oil on the very next ride. Immediately ordered new Nitrons.My 1985 Ducati MHR came with schrader valves in the fork caps (Marzocchi) as well as on the reservoirs of the Marzocchi Strada rear shocks.
I think the rider's manual said something like 4 psi max in the forks and around 25psi in the shocks. I might be mis-remembering the numbers, but whatever they were, they were impossible to achieve without a special hand pump and gauge. Even then, the volume inside is so small that you'd lose half the air in the "pssssst" when you take the pump fitting off. Totally impractical.
I just used the valves in the forks to occasionally vent them to atmospheric pressure. They never built up much pressure in anyway.
I fixed the Strada shocks by chucking them in a box and fitting some decent shocks to the bike.
