Gents
Sprag clutch has been 'slipping' sometimes instead of turning engine. Just want some advice on the repair process.
When motor had last major work I stripped sprag, replaced springs, cleaned, reassembled. I dont recall replacing rollers, so I should do this time huh. I can buy them singly from a bearing shop, or must they be ordered from a Laverda parts supplier? I'll check plungers again, but would expect they're ok?
I cant see anything else wrong with the sprag. Surface that the rollers engage on looks reasonable, and I'll get a local second opinion.
I see the bearing each side of the sprag doesnt appear as snug on the crankshaft as I'd expect, and the outer one not as tight in the alloy cover as might be expected. Looks like I'd put some bearing installation loctite on the outside of the outer sprag bearing to try to locate it better in the case. Any advice on how 'secure' these bearings should be. They seem in reasonable condition, but I'm inclined to replace them as a matter of course.
And - with the IIS ignition wires not all that easy to disconnect from the white fitting at the pickup end, so I'm inclined to leave them in place, fitting a new gasket by putting a cut through the outer part (dry) where the wires go through. Should I put gasket compound both sides? Doesnt look like I did last time it was off.
Any advice appreciated.
Thanks
Andre
Thanks
Andre
