Yours is a series 1. Cover just comes straight off after having removed the chain tensionner screw. Ignition is on the other sideHey, I'm just about to attempt a similar operation on my Mirage TS 1200, to which I posted for some advice help in getting to the clutch plates & process involved. I see here there is a discussion about ignition pickups! Is this something I need to be aware of, or is it only specific to the later model? Mine is a 1980 TS Mirage Engine 2988. If this helps. Thanks.![]()
Thanks. Interesting apart from the ignition difference, was anything else changed / different on a series 2 version?Yours is a series 1. Cover just comes straight off after having removed the chain tensionner screw. Ignition is on the other side
ClutchThanks. Interesting apart from the ignition difference, was anything else changed / different on a series 2 version?
What was different about the clutch?Clutch
