Smartv11
- Meopham, Kent
Generator light is staying on...
Voltage across battery terminals is not rising, so looking to the generator bushes, but some of basic questions please;
1 - Polarise the generator - I read that I need to connect a jumper lead from DF to generator frame, therefore grounding the DF connection. To be doubly sure the generator frame is say the generator mounting bolt?
2 - the Bosch voltage regulator - this is rubber mounted, do I need to connect an earth cable from D- terminal on the voltage regulator to the frame? or is earthing at the generator terminal sufficient?
3 - Generator bushes - where can I get these from, I'm guessing they are Bosch parts?
Hopefully, one or more of the above should solve my Charging light?
Kent, Uk
Kent, Uk
