piranha-bro2
- Melbourne
In the process of fitting a new inner web to a late SF1 motor (mid 15,000s) that's ratted out the RH spline and noticed that the drain hole that runs from the front right stud to the gap between the starter freewheel seal and the RH main bearing (gravity oil feed to RH main and starter needle roller) ... is missing. I can only guess that siesta time got in the way just as Lorenzo was about to finish off his case (of vino??) and he forgot to drill it.
I've got two other SF cases here (one early SF1 the other early SF2) and they have them ... as does every other SF I've ever worked, so must assume it's an oversight at the factory. Out of interest has anyone ever seen one like this? I'm in the process of drilling it, but it ain't easy, as barrel and case studs get in the way everywhere and it's a very awkward and tight angle to get right by eye.
Doesn't seem to have had any ill effects on oil supply, but drilling it regardless - and no, the spline didn't rat out due to lack of oil ... that was the after effects of a major seizure that left the rod in the shape of a horseshoe!
Quentino
Quentino
