SF Engine Mount Spacers
chrisk
Can anyone tell me the length of the top rear engine mount left & right side spacers please.
I've fallen foul by asking similar questions (  ;) Poffer), but I'll trust you!
Spacers may be fitted if needed.  Normal practise is to pull the engine up to the RH mounting lugs and add spacers as required to the LH lugs.
That's all good, remember this in going in a non Lave frame, so I'll ask in another way, which is where I was heading.
Are the (outside flanges) of the top rear mounts, actually equal distances from the centre line on the motor?
Guess you'll have to install the rear wheel and the engine cases with gearbox output shaft to get the chain run right, and go from there.  Who knows what the expert welder had in mind... enough surprises already. ::)
