Lyndoneil
- Towcester uk
Sorting throigh the potential problems on this recently purchased SF2, thought I would check out the starter freewheel clutch, as occasionally it made an unpleasant scrounging sound on the starter button, not always, but enough.
Almost wish I hadn't, but it would have been worse issues stored up for the near future.
Having removed the sprag clutch, only 3 of the rollers were actually doing anything, so only 3 springs and only 1 pin had not split into 2 pieces one way or another, but unfortunately 2 of the pins are seized deep in the holes and do not want to come out, and although I have not drilled the rivets out and removed the back plate, it appears the inner ring that holds all the pins, springs etc is fractured.
So I have to either replace the whole lot or parts,
How would I rivet it back together, the sizes look awkward?
Anyone have a reasonable used one?
All the bits I'm having to replace are f?????g expensive, either that or everything with Laverda's
Is expensive anyway.
