chrisk
- Brisbane, Australia
CLEMTOG said:Shaun is correct, you should have square bideied fuekl taps if you are bothered about poin point acuaracy (I am not0 but the original Paoli taps are no longer available, an aftermarket type is priduced, but the square body is smaller and still looks wrong, The only way is to get a pair of knackered originals (not easy0 and rebuild them (quite simple)
By thew way
as usual all the above diagnosers could be wrong, I would bet a penny to a pound of pot, that you have drilled out the rivets in the clutch drum in order to replace the cush drive rubbers, and the replacement bolts (and washers) are now sticking out too much, and are contacting the inside of the primary chain case, they will have cut a groove, and this lessens the noise, plus it will change with hot/cold cycles as everything grows and shrinks,you need to get the primary case off and have a look, that swarf going round will not do your bearings a lot of good.I hope I am wrong, but you should check.
Youch, Clems got a good point. Best you check it out sooner than later!
