smlav
- Shropshire UK
My SF1 has 36mm PHB’s, standardise air filters. Carbs were cleaned and refurbed by Paddy back in 2019. They have
Mains 140
Pilots 50
Slides 50
Atomisers 265AB
Needles K1
I had a problem of hesitant pick up at very low throttle opening, seemed worse with poor fuel (95 octane rather than 98/99), which responded well when I opened the mixture screw to 1.75 turns out, and would probably improve a bit more to being 2.0 turns out. So I’ve ordered 55 pilots which I think is what is needed, as I understand 1.5 turns on mixture screw is optimum.
My question is that reading the forum shows standard needles should be K2. Should I fit these as well - obviously I’d do the pilots first, test ride, then needles; one thing at a time etc. My understanding is that the needle affects mixture throughout the throttle range, and K2 is richer than K1. The needles in the carbs at the moment are on their middle notch. Is there much of a difference between K1 and K2?
Thanks
Sean
Mains 140
Pilots 50
Slides 50
Atomisers 265AB
Needles K1
Thanks
Sean
