Jedforce
- New Zealand
Hi, I need a set of ND instruments / gauges for my SF1, any leads would be great, I`m located in NZ, thanks
MarnixSFC said:With the blinkers and ND switches it had just as hefty a wiring loom as the SF2 at the time.
Marnix
Paul Marx said:I do have some instruments kicking around but not in the condition of Marnix's.
helicopterjim said:If you stop kicking them maybe they will be in better condition.
Jim
Paul Marx said:You don't understand soccer do you?
helicopterjim said:All I know about soccer is you only have to pretend to kick them and they completely self destruct ....... physical contact is not necessary to cause extraordinary reactions.
Jim
Paul Marx said:Soccer is the perfect example of a non violent sport.
That's the reason the violence has been transferred to the spectators.
Look at the Roman games or tennis. The violence is in the stadium. The spectators are well behaved.
MarnixSFC said:I have a set taken from an SFC, unrestored with wonderful patina, with original bracket. To use the bracket with the Bosch ignition switch of the SF1, then all you need to do is open up the hole a little.
PM if interested.
Marnix
