chrissoz
- Sydney, Australia
Finally have my SF1 back together and it is looks good.
Full rebuild including all new electrics based on M-Unit - new coils, new regulator etc.
Runs well - still some carb tuning to do and sorting out other small issues.
Biggest problem so far is lack of charging - have a new Sachse 5a regulator. Has connections B- earth, Battery B+, gen field coil (DF), gen output (D+) and 61 which wires through the gen light and back to in ignition - so is +12v when ignition is on.
On the generator DF shows 28 ohms to D- (earth), D+ shows 24 ohms to D- (earth). DF to D+ shows 4.5 ohms.
Gen light comes on with ignition but never goes out. DF is only showing 1.5v at idle and 2.5v at (by ear as tacho is not connected) 4000. I would kind of expect this to be higher as the regulator should energise the field coil?
B+ battery output from regulator is only 1.5v rising to 3v.
Generator was working find before the strip down - have recheck all the crimps and all look find. Anyone have suggestions for further troubleshooting - do the resistances for the gen look correct?
