i think Lee means 3 o'clock or 9 o'clock. But the technique he describes is the way to go.The keyway must face either at 3 o clock or at six o clock. You can remove the drive sprocket nut with a rattle gun first, then as you rotate the oil pump gear carefully pull it outward at either forward or backward spots, you should be able to feel it. Do not use a tool to pry it out.
ok, understandthat is is, gently tugging by hand as you turn very slowly, and you will find it.
NOT AT ALL LIKE THE TRIPLES TOTALLY DIFFERENT
Oops. All clocks are digital now aren't they?i think Lee means 3 o'clock or 9 o'clock. But the technique he describes is the way to go.
