CDHE
- Boulder, Co
I think Redax have the correct ID billet flanges ….. but then, I was wrong once beforeMy new exhaust pipes (from Wolfgang) are stepped up to 43.5mm OD at the head, and the exhaust flanges have an ID of 40.5mm. Thoughts on how to proceed?
Do you use the Big-Valve-Head ( 36mm DellOrtos ).My new exhaust pipes (from Wolfgang) are stepped up to 43.5mm OD at the head, and the exhaust flanges have an ID of 40.5mm. Thoughts on how to proceed?
You can measure it.I don't know which head I have. Bike did not come with carbs. Previous owner had the head blueprinted by Engine Dynamics
You will need 2 x half rings for each header, and a flange with recess for said half rings.i can bore the flanges out, but still confused about how the pipe is affixed in the head.
See pic. He has the crossover pipes.Slide the flanges over from the exhaust side of the pipe! Ciao, Gert
Small-valve-head headers with SF1/2/3 big-valve-head flanges I'd say. Just need to coordinate the bits.SF2 with small-valve Head?
All of us 750 owners back in the 70s ditched that crossover as all it did was reduce cornering speed and made the bike too quite!!!
Made fuck all difference to mid range andaddedremoved a shit load more weight. I'm talking SF1,2,3
Bought my bike in pieces, so I won't be able judge any changes, but I do plan to run it on the local Ducati shop's dyno....Hopefully yet this riding season!When you get that exhaust fitted please let me know how you like it and if the cross over pipe makes a performance difference. My 750 SF came w/ a Malcolm Cox exhaust w/ no cross over, and I've heard it affects mid range. I haven't ridden the bike much yet to tell how it's performing
