Bikepirate
- Brisbane Australia
I'm still having a problem with the Brembo Front Brake. I have now changed the the seals etc in the callipers and also replaced the complete mechanism in the master cylinder per the procedure obtained from Paul Marx (bless him!). I still can't obtain any pressure. Fluid comes out through the bleed nipples when loosened
I'm using DOT 3 Fluid. Is this OK?
A mate has recommended pumping the fluid back through the bleed nipples to get rid of any air. Any recommendations on this and a suitable pump kit?
