ksoholm
- Bellingham, WA, USA
Lads,
I tried this Q on FB, but there's a spectrum of answers. During the test fitting of the swingarm without tightening the nuts and without the engine installed, I found 1-1.5mm end play between the swingarm bush and the frame flat.
There were no shims to take up the gap, the parts manual don't show any, nor does the Green Book reference them; it states that tightening the nuts takes up the endfloat.
Once the pivot pin nuts are tightened, is this end gap reduced? Will the ends just be rubbing away at each other brass-on-steel with a little bit of clearance keeping them from binding? How much clearance should there be once the nuts are tightened? Are we just relying on a bit of grease between the bush surfaces?
Thanks all -
Thanks all -
