CDHE
- Boulder, Co
drill some holes in those cupped washers?yep......hence the quicker ware rate.
No, the system is long lasting.drill some holes in those cupped washers?
Which helps a lot. On my bushed one it can pack tight against the grease gun unless I loosen it, and easily pump new grease through with it loosened.. I think some punters loosen the swingarm pivot nuts a little before applying the grease gun - to help the grease exude under pressure.
www.newmartstore.com.au
