SF3 clutch cable
JulianE
Bristol
Hello all. First post, though have been reading/learning/admiring for a while. I bought an SF3 6 months ago – Ged at GCS has had it in, pronounces it "not bad" – and I want to take it over to France next month. I feel it would be good to add a clutch cable to my luggage. Am I being over-cautious, and if not any ideas where can I find a decent one? Web searches aren't helpful so far and I've heard the Venhill (?) ones aren't great.
Thanks in advance ))
That's great thank you, Tippie. As I'm going through the circles of hell to access my FB account this morning (having moved to a new phone), I'll get round to JJ Cables as soon as Meta stop being utterly useless. Can you tell me, do they supply the extended clutch arm, or someone else?
I did, for several years, work unsuccessfully with Venhill to try to resolve the shortcomings of their proferred cables.
The limitations of the nipples, barrel and trumpet, that they stock, proved less than satisfactory.
Currently using a JJ Cables replaced inner. Not enough mileage to say whether it's going to last longer, but they were an absolute pleasure to deal with.
I'm definitely going that route. Thanks very much, J
Yes, take a spare clutch cable, and a spare throttle cable. Other option is a cable repair kit with screw on nipples and length of cable. Or both.
Whereabouts in France are you headed?
I bought a “heavy duty” Venhill clutch cable and thought it was built well, so what’s wrong with them and where can I buy the extended arm? I placed a coiled used one between the tool box and battery area as a spare and squirted some cable lube in the Venhill that doesn’t seem to seat into the clutch lever housing very well.
I found the Venhill “heavy duty” cable totally unfit for purpose. It made finessing the clutch impossible. Try using a clutch cable on the throttle if you want to know how unpleasant it was. I returned it and they gave me my money back.
I also have a bad opinion of Venhill due to a 500 clutch cable whose outer was much too long. prefer to make my own particularly considering Brexit extorsion.
Carry a spare by all means (certainly can't hurt). But as a reference, I've covered hundreds of thousands of km on my SF and have only ever broken one clutch cable. You'll find google will direct you to info on extended levers. I fashioned my own about 40 years ago.
Red supplies a complete kit for the extended lever. I got one for my SFC but haven't fitterf it yet as the bike only sees track kms so apart from starting and finishing I don't use the clutch. For road use I'd definitely be fitting it.
Thanks for throttle cable tip, Paul. I’m just going down to Brittany, as a tryout for a longer trip in future. Did you recently sell a beautiful SFC? I was very tempted by it
Highly reassuring! And will look into the extended lever on return, though I don’t find my clutch too heavy as is
Hello Julian,
Yes, SFC gone and replaced by a venerable British V twin.
Hello all,
delighted to report that the SF3 (and I) made it on its first foreign ride, Bristol to Brittany. 500-mile tour, huge fun. And no need for spare clutch cable. BUT I shall get the ignition timing perfected because I ache in the places where I used to play, as Leonard Cohen once sang.
