SF750 selector cover
Fitz
Cheshire UK
Hello all, I am nearly finished with my SF750 engine rebuild now. In the green book Page 84 there is a schematic showing the parts. Looking at the outer end (gear lever end) you have the lever, then a washer / shim, O-ring, then another washer / shim then the spring. Is the first shim outside of the cover to retain the o-ring. There does not seem to be much to hold that o-ring in place. I think it must be. 2nd question,
I have one of Malc's extended clutch levers, to fit it there is a small bracket in the kit to raise the cable adjuster to a similar height to the extended lever, this means I have to fix the plate to the original cable position, does anyone know what thread the cable adjuster is so I can source a bolt. My vernier measures 7.8mm and my thread gauge say its a 1mm pitch
Same adjuster screw for all, Marty! You must have a bodged cable... I find all sorts of stuff in there!
"Not much is needed to keep it in place, because it sits deep enough in the cover to not pop out."
as my Learned friend Marnix says, but also there is no real quantity of oil sloshing around on the shaft, so even if the O ring flops about and the lever rattles in and out it still wont leak oil from that point, just not good practice.
