Dellortoman
- Tasmania, Australia
Rob7 said:Is the Ignitech a direct change out for the DMC?
The short answer is yes, it can be. But only if you buy an Ignitech box that's compatible with the Laverda VR (magnetic) pickups. That way you're only up for the cost of the Ignitech ignition box. You'll need the 4-channel box for a 120? triple (around $300 I think).
Contact Red in Brisbane. He sells Ignitech systems in Australia. I'm not sure whether he stocks units suitable for use with the VR pickups, but I suspect he would as there would be other people in your situation. He will also set it up with a suitable program for your SFC 1000.
The long answer is ? A technically better solution than to stick with the original pickups would be to buy Red's complete ignition system and alternator conversion. I'll cost significantly more but includes an upgraded 3-phase alternator and a new Hall-effect pickup board as well as the Ignitech ignition unit. So it'll get rid of any issues with the 40(ish) year old pickups and wiring.
At the risk of ruffling Red's feathers, but to be fair, I should also acknowledge that Greg Parrish sells Ignitech systems in Australia (for both Hall and VR pickups). I don't know whether he provides a full plug-and-play system, with Deutsch connectors for the pickup wiring like Red does.
Anyway, knowing Red's history with Ignitech way better than I know Greg's, I'd suggest Red as your first point of contact.
