SFC 750 Neutral switch needed.
minigunz
Hello Members
So the previous mechanic must have thought the Neutral switch under the engine was the issue for stiff shifting.
This guy ground the complete spring-loaded nipple off completely and the only reason I found it was no neutral light
and I chased it all the way back to the Neutral switch.
To my surprise upon removal the nipple that positions the shift plate was ground off.
I talked with Wolfgang and he has none, so now I am pleading to the forum for the search on this part
Any help would be appreciated.
There must be a replacement that fits other motors that can be substituted for this.
Jeff Tuttobene
Hello Members
Jeff Tuttobene
I'll check my sacrificial 750 table of endless bits-
It's the same switch across all the models. Last one I brought was 2nd hand from Wolfgang maybe 20 years ago. That was for my 1200.
A problem on my SFC is that the neutral light stays on. Next oil change I'll be removing the switch to see whats going on down there.
if you cannot find one send me a message, I have them in stock, new and used
Zane Laverda's used same switch, ask 3C Moto if they have any left
