Nice CNC job - but why does it need a bronze bush for the axle? It's not a floating carrier plate? And is the length of that slot necessary? Can only move as far as the axle can in the swingarm?
The aluminium ?guide? on the swingarm has a large diameter, hence the long slot in the bracket.
The bush for the spindle should be steel, there you?re absolutely right.
The brake bracket is purchased from A Guiseppe, which also fits a spaceframe. They are made with a bronze socket, which is also a professionally correct solution.
