paulincayman
- Cayman Islands
So once again I've leapt in feet first , randomly bought a SFC etc 750 swingarm for my 77 3CL project , I'm fitting GSXR1100 wheels with a 140 already purchased, thought it might give me a bit more space over the stock swinger for the tire. I took some measurements and it is pretty much the same as the stock unit except for being about an inch shorter between front pivot and rear axle and therefore the shock mounts are an inch closer forward also. I would welcome input from anyone who has done this mod with regards to shock length and maintaining the stock geometry, I have not bought new shocks as yet
, so maybe also an an opportunity to tweak the geometry? ( no offence intended). I hate guesswork especially with the shipping costs..all comments welcome
Second point ,
It looks like the swinger has bonded rubber bushes in the pivot tube with metal bushes into those, the OD of the tube is the same as the stock 3cl item, so I'm optimistically assuming the guts are interchangeable having recently purchased the needle roller bearing kit for the stock item
, is that correct or am I in for more grief as usual?
Second point ,
