Be aware that there were 2 sorts of carriers (although a similar triangular shape was used), the early ones were different on each side (the LHS having an horizontal top edge, the top edge of the RHS plate coming down downward) while on the second model both plates were identical (sloped downward). If this is for a replica with the common exhaust fitted, you may need the second type.
