??? Forum saidThat's already a couple of years ago..
Yes, quite confusing Thomas. The 2nd of January fell on a Saturday in 2010 and 2021 and I seem to remember the bike was sold in 2010. Would have liked to own her for hill climb demo racing??? Forum said"Sam 2 Jan - 20:41". Normally, previous years are shown explicitly.![]()
Youtube-film is from 24.12.2009 - it seems you are right.
Thomas aus LAU
All the Martins I have seen have had wrap-around frames, vasty different from that. They were special because like most other aftermarket sports and racing frames they were light and strong and enabled Japanese engines to be used to their potential. To measure well it appears that the front main section of the frame is standard Laverda down past the rear engine mounts. Has anyone seen this bike in the flesh?What is special about a Martin, apart from it's rarity, particularly outside France?
Just the copy of other frames.
That one is remarquably similar to a standard frame.
Why would you wrap a frame 'around' a 750 motor?All the Martins I have seen have had wrap-around frames, vasty different from that.
Looks like it. We saw quite a few Laverda in Langemark.The same ?
Languemark (B) 199? , Paul.View attachment 61893
Martin first made spine frames, à la Egli.All the Martins I have seen have had wrap-around frames, vasty different from that. They were special because like most other aftermarket sports and racing frames they were light and strong and enabled Japanese engines to be used to their potential. To measure well it appears that the front main section of the frame is standard Laverda down past the rear engine mounts. Has anyone seen this bike in the flesh?
It is, but monoshocked. I love those Campo wheels.Standard 750 frame. What's all this about Martin?
Probably for the same reasons you would for loads of other motors.Why would you wrap a frame 'around' a 750 motor?
Jim
Because with almost every other frame made for them you cannot get enough length on the inlets and still run filtration if you want to run big carburettors.Because you can?
Jim
I always wondered whether an SF/C motor is strong enough to support the steering tube from the top cover, nothing in between, and a rear end assembly mounted off the rear engine mounts.
Then I like them too. Hmmm, but the spokes on the gold ones look much.... wider, no. Longer, no. Thicker, no. Flatter,no.
