Hi,
I'm going to install an aftermarket speedo onto the Atlas. I prefer to keep the standard block connector in case I want to retro fit. Ideally I'd like to put the digital output wires into a block that I can just plug into the standard Atlas connector (probably the same as with the Laverda triples).
Is it possible to buy these blocks and if so where? If not has anyone else come up with an alternative solution that saves the original block on the main loom?
Thanks
Nick
Thanks
Nick
