michipons
- Palma de Mallorca
I started this thread in “wanted”, but I will continue it here as it makes more sense.
So, finally I have the starter working.
Thank you to Piet for his spares parts, I have to admit that is a strange feeling to open a spare item kept in his original bosch box from 50 years ago. Is a kind of privilege.
So my conclusions are. You can paint the inner part of the case, also the coil cores, and the brush plate. I just had to peel off the contact between all cases to ground the brush plate with the aluminium case and the engine. Cerakote is not affecting the magnetic fields
. So now is all protected against rust.
I had some troubles with the brushes. The first ones I got where too short and thick, so it was really hard to weld them and twist the little wire for such tight curve. I sourced another set here:
www.escobillas-de-carbon.es
18 is a bit too long and had to lime them to 14mm but for the rest, perfect and easy to weld.
The NOS coils from Piet were just perfect, a bit time consuming to adapt them to the case so that all fits in place.
Soldering the brushes… well, recommend you a 100W welder. All other is not enough.
It is not totally assembled but enough to make the first test (see video). And spins like crazy!! The first time took 1/2 seconds before start spinning… the longest 2 seconds of my life
Miguel
ESCOBILLAS DE CARBÓN AMEG MOTORPARTS 7X10X18 COMPATIBLE CON MOTOR DE ARRANQUE BOSCH
ESCOBILLAS DE CARBÓN 7X10X18 COMPATIBLE MOTOR DE ARRANQUE BOSCH 0001207001, 0001207018, 0001208004, 0001208008, 0001208025, 0001208039, 0001208040, 0001208041, 0001208044, 0001208049, 0001208051, 0001208052, 0001208053, 0001208054, 0001208100, 0001208101,
