Starter clutch
Rush
Lincs
Afternoon people,
Trying to repair my starter clutch when stripped in down it only has 5 springs and pins but 6 rollers so 1 is effective free on closer inspection the location hole for the spring is blocked assuming this was the pin witch Jamed In the hole, will it work with 5 or do I drill the rivets out then the hole , bike is a Palmelli SFC B/R
Don't reassemble it with 5 springs/plungers/rollers. Springs are wear parts, and rollers should also be checked. Clean and oil the whole caboodle, and reassemble with at least new springs.
Edit: The inner surface of the starter clutch on the crank on which the rollers act upon should be reasonably smooth.
Common problem for plungers to become stuck in the holes - the springs are usually in pieces under them. IIRC later models had external holes in the starter freewheel to allow a thin prod to push out the stuck plunger. You could try using inertia and rapping the starter clutch on a piece of hardwood and the plunger may dislodge.
Failing that - and rather than remove the cover and rivets - you could try and drill the little holes so you then have permanent future access. I made up a little jig to give me the angles of the holes (used to create the scribed lines on the freewheel in the pic below) then mounted the freewheel in my lathe vice and drilled through - I had to create a flat surface with a mill bit first, so the drill bit could be accurately bored through. Pics below might explain a little better.
