Stater Gear (14 tooth) and Splines
Hello,
I noticed the starter gear was a bit loose on the splined starter shaft and have bought a new gear. The new gear is a slightly better fit but remains a bit loose in that will slide up and down the shaft. There is no obvious rotational slack on the splines. My understanding is if there is wear on the splines eventually the starter turn and strip the splines.
How tight should this gear be on the shaft? Does the starter shaft need replacing also?
Regards
Mike
Mike,
Which model are you referring to?
Only models that have a splined starter shaft would be the 750, GT to SF3, and they have a sprocket fitted to it.  If that is your case, a little axial movement is quite normal and the splines are not harmed in any way, the starter will most probably out-live all of us.  Fit it with a little grease and lubricate occasionally.
