- Calgary, Alberta, Canada
Hi all
On my desk at the moment I have the complete Bosch BTZ ignition that I removed from my RGS (120 degree crank), as well as the complete Bosch BTZ ignition I removed from my 82 1200 TS Mirage Series 2 (180 degree crank). Two questions.
1. Comparing the two ignition rotors side by side, looking at the rotor from its "front" end (the end you see when it is installed), the keyway on one rotor is at about 3 o'clock, the keyway on the other rotor is at about 2 o'clock. I forget which came off which bike....... ??? ??? :-[ :-[
Which rotor is for the 120, and which rotor is for the 180?
2. As can be seen from the photo, the cloth wiring cover from the pickup plate to the Bosch boxes was cut on my 82 1200 TS, and further, all four wires have the actual insulation on each wire missing for about half an inch or more. This is how the wiring was when I took it off the bike, it almost looks like someone in the past might have done this deliberately? Anyway, the wires themselves are intact, what would be the optimum way of repairing this? My first reaction was to just cut all four wires and put proper splices in with shrink wrap on each repair, but now I am wondering if it would be wise to cut and splice the wires or just cover each bare section?
