My SF1 was off the road for a long time, needing a top-end job. I finally had Scott Potter do that plus a functional restoration. When I started riding it, however, there was a shifting problem, difficult to shift, more or less stuck in second gear. I discovered the locknut on the shifter eccentric was loose so I figured a quick adjustment would put things right. I've done this job on both my 750s and the Jarama before. I've got the rear wheel lifted and sparkplugs out, turning the engine at the crankshaft nut. The gearbox was in neutral to start. pushed down into 1st, on my way to 4th for the fine adjustment, but it won't come out of gear now. I can't get back to neutral. I can turn the engine/gearbox/rear wheel from the crankshaft or the rear wheel without hearing any funny noises but the shift selector refuses to move with what feels like a reasonable amount of force on the shift lever.
Ideas welcome, especially ones that don't begin "First you'll need to split the cases?"
Eric
Eric
