Cosi
- Kingscliff
Finally, my first real contribution to the technical section, I must be learning....laverlesmains said:Good point - that's something I've got in the tool box..
Switching the DMC off (ignition or kill switch) and back on will reboot it...useful if the engine backfires when trying to start it.Not sure if there's an error protection circuit in the DMC, but it would require removing the connector and letting the DMC calm down before I could start it again
Have you check to make sure the triggers are wired correctly? They should spark when a blade is brought towars them vs. pulled away.laverlesmains said:With both the original and replacement (from Red) triggers I cleaned up and insulated the fragile wires running from the triggers.
If you swap polarity of the pick-ups they function differently.
In stock configuration, the pulse is generated when the trigger advances towards the pick-up. When polarity is reversed, the impulse will occur when the trigger has passed the pick-up. Easy to check with a slim screwdriver. Either the spark occurs when the screwdriver hits the pick-up (stock), or when you pull it off the magnets (reversed).
